richie9648 Posted December 18, 2022 Share Posted December 18, 2022 (edited) Hi Hope this is the right place for this Got an issue with the waste pipe from shower and bath in that the waste water (not poo or pee) will travel down the pipe and just overflow where it is positioned on the gulley and thus floods the garden. The drain is running fine by the way and not blocked. video attached which probably explains a a lot better. But been getting different advice from the trades - one guy quoted £300 to sort whereas another just said get a 45d bend and you will be done any suggestions ? IMG_0781.MOV Edited December 18, 2022 by richie9648 Link to comment Share on other sites More sharing options...
Gus Potter Posted December 18, 2022 Share Posted December 18, 2022 As an immediate and temporary solution you could modify the hopper below to stop the overspill. You'll probably need to dig a bit of a hole and need a straight coupling to connect the hopper to the existing pipe. @Nickfromwales may pitch up with a better idea so will defer if so. Link to comment Share on other sites More sharing options...
ETC Posted December 18, 2022 Share Posted December 18, 2022 The gully trap is either blocked or is not connected to the drainage system. This looks like the pipe is connected to gully trap serving a rainwater downpipe. You really should be separating the foul and storm systems. Connect the foul drainage pipe to a new gully trap and connec5 the gully trap to t(e foul drainage system. 1 Link to comment Share on other sites More sharing options...
Gus Potter Posted December 19, 2022 Share Posted December 19, 2022 2 hours ago, ETC said: You really should be separating the foul and storm systems. Good point of note. If you have a house say built circa the 1950's then please check that you don't have a separate rainwater and foul drain system.. your plumber should know this. If you put your sink waste into the rain water drain this goes straight to the watercourse and kills wildlife. Link to comment Share on other sites More sharing options...
richie9648 Posted December 19, 2022 Author Share Posted December 19, 2022 7 hours ago, Gus Potter said: Good point of note. If you have a house say built circa the 1950's then please check that you don't have a separate rainwater and foul drain system.. your plumber should know this. If you put your sink waste into the rain water drain this goes straight to the watercourse and kills wildlife. hi - its c1930s and as far as I can tell there is only one drain service that runs outside the side of the house Link to comment Share on other sites More sharing options...
