zoothorn Posted December 17, 2022 Posted December 17, 2022 Hi chaps, Im going plumbing potty today.. 2 threads. Simple question if I may: got new WM, all in place, it's grey 1" corrugated waste pipe exits the WM **only 6" above/ away from the top of my white wall corner drain pipe. The WM pipe's way too long, so it's going in a big loop down first, around, up.. & into my wall pipe. Is this ok, or is my WM draining compromised by this big pipe loop? If it's better cut right down, how far down the wall pipe should it go? Thank, Zoot
Tennentslager Posted December 17, 2022 Posted December 17, 2022 Stuff it fully in the pipe just in case it wriggles free
zoothorn Posted December 17, 2022 Author Posted December 17, 2022 (edited) 13 minutes ago, Tennentslager said: Stuff it fully in the pipe just in case it wriggles free Hi tennents, if I do this the pipe sits 500mm high/ proud of the WM. According to www info, the WM drain pipe should insert only about 5" down the wall white pipe, so as not to affect any exiting water. So if I do this, I have a big loop. What do I do with this loop? Edited December 17, 2022 by zoothorn
Pocster Posted December 17, 2022 Posted December 17, 2022 (edited) I’d cut it ( but not too short ) then zip tie it or similar around the pipe and back to the machine - so it’s got no chance of coming out . Edited December 17, 2022 by pocster
zoothorn Posted December 17, 2022 Author Posted December 17, 2022 14 minutes ago, pocster said: I’d cut it ( but not too short ) then zip tie it or similar around the pipe and back to the machine - so it’s got no chance of coming out . Good plan. Ok so do know then that it's -not- a good idea having this loop then? Common sense might say it isn't, but I'm cutting off most of this grey pipe doing this.. leaving just 12". Does that seem right to you? Kinda seems rather drastic/ wrong/ but I can't see any other option apart from leaving as is, with this big loop. This pipe starts inside the machine, so no 2nd chances to redo it if I cut it.
Pocster Posted December 17, 2022 Posted December 17, 2022 3 minutes ago, zoothorn said: Good plan. Ok so do know then that it's -not- a good idea having this loop then? Common sense might say it isn't, but I'm cutting off most of this grey pipe doing this.. leaving just 12". Does that seem right to you? Kinda seems rather drastic/ wrong/ but I can't see any other option apart from leaving as is, with this big loop. This pipe starts inside the machine, so no 2nd chances to redo it if I cut it. Big loop is bad . Also once cut if you ever need to extend the waste pipe again you can get couplers etc. to do that . How long is the white wall pipe the WM waste is going into ?
dpmiller Posted December 17, 2022 Posted December 17, 2022 don't cut it, and ignore the extra length. shove a bit down the pipe, use the supplied U-clip thingy to form the bend, done.
Pocster Posted December 17, 2022 Posted December 17, 2022 1 minute ago, dpmiller said: don't cut it, and ignore the extra length. shove a bit down the pipe, use the supplied U-clip thingy to form the bend, done. I think the problem is the WM waste pipe is too long . Even fully inserted in the waste pipe @zoothorn will have a big loop of waste pipe hanging out . It probably won’t make much difference tbh I.e washer will still pump it out ; but looks crap .
Pocster Posted December 17, 2022 Posted December 17, 2022 Could just loop the excess pipe behind washer and zip tie again . Then it’s not cut nor visible . Depends on bravery skills 😁
dpmiller Posted December 17, 2022 Posted December 17, 2022 if it's down the back of the machine, who cares?
Pocster Posted December 17, 2022 Posted December 17, 2022 5 minutes ago, dpmiller said: if it's down the back of the machine, who cares? Sure . I *assumed* it was visible . Still want to zip tie it though . If it’s a long pipe and gets pushed out the waste pipe it’s going to be messy .
zoothorn Posted December 17, 2022 Author Posted December 17, 2022 55 minutes ago, dpmiller said: if it's down the back of the machine, who cares? Hi dpm, So left as is, the big loop is definitely no issue?
dpmiller Posted December 17, 2022 Posted December 17, 2022 that's the length supplied. the drain pump is more worried about height than length tbh
zoothorn Posted December 17, 2022 Author Posted December 17, 2022 1 minute ago, dpmiller said: that's the length supplied. the drain pump is more worried about height than length tbh Ok thanks- I had no idea how much pressure this drain pump is, basically my the thinking you see. Will do as you suggest & zip tie it/ if any issue I can shorten it later I guess. Cheers, zoot
