Patrick Posted December 12, 2022 Posted December 12, 2022 Been running mvhr for around 4 months now . Vacuuming the filter and cleaning it regularly (1nce a month) and still there is this dirt circle building around the mvhr outlets. Any one else had or has that problem?
MJNewton Posted December 12, 2022 Posted December 12, 2022 (edited) I haven't, but then my vents don't fire out quite as close to the ceiling as yours appear to. That said, I don't get much (if any?) dust/dirt building up inside the vent and its supply pipe as the air being pumped in is reasonably well filtered. Do you have a filter installed in the MVHR unit? (Edit: Sorry, you quite clearly referred to the presence of a filter!) Edited December 12, 2022 by MJNewton
Marvin Posted December 12, 2022 Posted December 12, 2022 No problem here. Four years now and no marks. Is the insulation tight against the ceiling and pipe? What are the filters like? Where is the MVHR drawing fresh air from?
Marvin Posted December 12, 2022 Posted December 12, 2022 On 12/12/2022 at 21:14, MJNewton said: I haven't, but then my vents don't fire out quite as close to the ceiling as yours appear to. Expand Nor do ours.
Patrick Posted December 12, 2022 Author Posted December 12, 2022 On 12/12/2022 at 21:15, Marvin said: No problem here. Four years now and no marks. Is the insulation tight against the ceiling and pipe? What are the filters like? Where is the MVHR drawing fresh air from? Expand Insulation is cellulose blown into the ceilings. Filters are original ones from ubbink Fresh air drawn from outside -close to the gutter... Not specifically dusty or dirty there.
Roundtuit Posted December 12, 2022 Posted December 12, 2022 Yes, similar to yours; a really fine dust that seems to stick by static. It comes off easily enough with the brush attachment on the hoover. Filters are changed every 6 months. 1
MJNewton Posted December 12, 2022 Posted December 12, 2022 (edited) Maybe we all get it, but only certain types of vent that blow the air against the (slightly rough) ceiling surface end up 'catching' it. Here's my type, which whilst intended to throw air sideways by virtue of the internal profiling, won't ever throw it towards the ceiling so my dirt/dust is probably just landing elsewhere in the room! Edited December 12, 2022 by MJNewton
j_s Posted December 12, 2022 Posted December 12, 2022 Same issue here but only on a couple of inlets. 1
