There is an internal door that I want to insulate (thermally, and possibly phonically as well), as it leads to a stairwell that we cannot insulate. (It's a very tight stairwell going to the attic.) However, the space under that stair is also the planned location for the cat toilet, and I do not know whether we will succeed in herding the cat into the attic every night. Are
(a) insulating the door
(b) carving out a cat-door in the bottom part of the door
compatible goals?
42 minutes ago, Nick Thomas said:
"3.979 W/(m²K) is a very good result for a pet door and far outperforms all standard catflaps. A typical catflap with an acrylic flap of 2-3mm thickness has a U-value in the order of 6/6.2 W/(m²K). The lower the figure the better."
Ubakus gives a 3mm sheet of polycarbonate a U-value of 4.444 W/(m²K) so if a regular kitty flap was 0.2m square (0.04m2) that would be a 3.5W loss with delta T of 20oC. The ones with a magnetic closer are pretty good at being draft free.
Ah, interesting. You mean, like this one?
https://www.amazon.com/Catwalk-W-MCD-Multi-Magnetic-Cat-Door/dp/B0016H9GK6?th=1
But that's a lockable one (opening for a specific cat with the right microchip or key around his or her neck). Are there simpler ones?
Edited by Garald
No, I don't think so. The magnetic item in that ones description is to do with the locking system. We had one where the plastic flap had a magnetic strip around its perimeter and this firmly pulled it into the closed position. It had no lock other than a two-way barrier selector.
