Hi,
we are nearly ready to install internal PIR in our timber frame walls.
The trouble is that out screed to ceiling joist height is 35mm higher than full sheet of PIR.
Would it be best to:
a) lift boards 20mm off the ground and foam up with expandable foam later? There would be tiles and adhesive later so I guess it would be ok? Then remaining 15mm on top, do the same thing because there will be a plasterboard applied?
b) fully plant it on the floor tight to screed and foam up the top?
c) install a row of pir boards horizontally, and do 650mm pir cuts from a vertical board, and generate a lot of cutting and waste?
what would a self-build-hubber do?
thanks!
bart
Aren't there noggins in that would stop a full board length being installed?
I would install a full board then a 35mm slither off cut, expand foam any gaps, then alu tape over joints
Edit: it was my assumption that your insulation is going in the cavity, however it sound like it may be on the inside of the timber.
Edited by Moonshine
d) Buy a sheet of 30mm PIR and cut into strips. Put that on the screed with full sheets on top. Fill 5mm gap with foam.
Thanks guys, both good suggestions.
I will probably end up cutting 35mm slivers to top in order to keep alu faces back and front rather than top and bottom
thanks!
oh, and would it be good to have horizontal battens top and bottom of the wall to give the plasterboard better bedding or would it be counterproductive?
Foaming up is your best option
You can always cut it off with a saw and foil tape it Cutting 30 mil rips would be difficult to keep the foil on
Not with a skillsaw?
I like this idea
