Moved into house recently and the unit looks like this. How do I isolate power? There only seems to be a switch for the master and not individual circuits.F49BF4D2-30D6-4F53-95AC-F1DAB0B373BB.thumb.jpeg.060c457026dc5f385f97bbaf23f54974.jpeg
You don't see many like that anymore. Pull out individual fuses to isolate the circuits - although I'd throw the main breaker first. Safety wasn't such a priority when these were installed. The fuse carrier will expose a certain amount of live conductor as it comes out.
Worth an upgrade then 🤣
Old MEM board, sticky fuse, wiggle it about, plastic breaks up and you get a good crack from it. …. Not that I would know 😉
15 minutes ago, markc said:
Definitely :)
Is it ok just to upgrade the MCBs (I think that's what they're called) and keep the main unit? I'd be happy having a go at this, assuming I could just switch the main switch off and then change the MCBs.
No.  Any mcb's you find for that will be old / second hand, if you do find any new ones they will silly money. And an rcbo for that is like hens teeth.  Spend the money on a  new up to date consumer unit.
Any particular brands you'd recommend?
Are these any good:
https://www.screwfix.com/p/british-general-fortress-16-module-10-way-populated-high-integrity-dual-rcd-consumer-unit/466px
https://www.screwfix.com/p/british-general-fortress-22-module-12-way-populated-high-integrity-dual-rcd-consumer-unit-with-spd/208kr
I have fitted many of the SF BG boards, nothing to complain about
My favourite if money no object is Hager (what i have in my house)
Thanks - am looking at this unit:
Does this look ok as a replacement?
Do you think I need to order any extra MCBs etc?
2 minutes ago, ProDave said:
You will need one more 32A mcb as you presently have 6 30A fuses and that Cu conly comes with 5 32A mcb's.
Thanks for the help. Much appreciated!
