I have two under floor heating manifolds, each with a dedicated circulating pump.
On closer inspection, I've found they both pumps have variable speed settings.
Any thoughts as to what speed these pumps should be running at?
I think standard practice is to put them on the slowest setting, but I’m not sure why.
Yup. Flow can be stupidly low, but still give you the heat you require.
A lot to do with the type of emitter though, eg thick vs thin ( slab vs screed ) will perform very differently.
