Hi guys,
Could anyone recommend a good taping and filling product for plasterboard? I was thinking of using Gyproc joint filler and Gyproc Easi-Fill 60 however the knauf joint filler is half the price!
Any hints and tips would be gratefully received!
Easi fill is no good for jointing
and would work out expensive
You need joint filler for the tape
Then Gyprock joint cement for the next two coats
Once mixed the joint cement will last for days if you cover the top of the bucket
Cheers @nod. Just to confirm - Gyproc joint filler for the tape then 2 coats of Gyproc joint cement instead of 2 coats of Gyproc easi fill 60.
Is Gyproc a better finish - Knauf Premium Joint Cement seems much cheaper, but is it any good?
Easifill is a finisher. The bulk of the work, including bedding in the tapes, needs the joint filler ;)
Get that as flat and smooth as possible and use Easifill to complete, sanding and adding more as required.
Easifill goes off much quicker, so only mix up what you can use, making bigger mixes as you get used to using it / workable “open” time.
Yes
34 minutes ago, nod said:
Yes
Sorry didn’t see the last bit
Theres no difference between the two
Like board finish and multi finish
Personal preference
39 minutes ago, jen and mark said:
When dry, what do you recommend for sealing the PB prior to painting? mist coat? PVA? expensive primer?
None of those things!
High opacity Matt white emulsion, a couple of coats, and then sand that down to a finish.
 Super Leytex paint - its what its designed for.
