jen and mark Posted October 15, 2022 Posted October 15, 2022 Hi guys, Could anyone recommend a good taping and filling product for plasterboard? I was thinking of using Gyproc joint filler and Gyproc Easi-Fill 60 however the knauf joint filler is half the price! Any hints and tips would be gratefully received!
nod Posted October 15, 2022 Posted October 15, 2022 Easi fill is no good for jointing and would work out expensive You need joint filler for the tape Then Gyprock joint cement for the next two coats Once mixed the joint cement will last for days if you cover the top of the bucket
jen and mark Posted October 15, 2022 Author Posted October 15, 2022 Cheers @nod. Just to confirm - Gyproc joint filler for the tape then 2 coats of Gyproc joint cement instead of 2 coats of Gyproc easi fill 60. Is Gyproc a better finish - Knauf Premium Joint Cement seems much cheaper, but is it any good?
Nickfromwales Posted October 15, 2022 Posted October 15, 2022 Easifill is a finisher. The bulk of the work, including bedding in the tapes, needs the joint filler Get that as flat and smooth as possible and use Easifill to complete, sanding and adding more as required. Easifill goes off much quicker, so only mix up what you can use, making bigger mixes as you get used to using it / workable “open” time. 1
nod Posted October 15, 2022 Posted October 15, 2022 4 hours ago, jen and mark said: Cheers @nod. Just to confirm - Gyproc joint filler for the tape then 2 coats of Gyproc joint cement instead of 2 coats of Gyproc easi fill 60. Is Gyproc a better finish - Knauf Premium Joint Cement seems much cheaper, but is it any good? Yes
JohnMo Posted October 15, 2022 Posted October 15, 2022 My house was done with Knauf, the guy doing it told me to buy that, as he had used everything else and liked that best.
nod Posted October 15, 2022 Posted October 15, 2022 34 minutes ago, nod said: Yes Sorry didn’t see the last bit Theres no difference between the two Like board finish and multi finish Personal preference
jen and mark Posted October 16, 2022 Author Posted October 16, 2022 When dry, what do you recommend for sealing the PB prior to painting? mist coat? PVA? expensive primer?
Nickfromwales Posted October 16, 2022 Posted October 16, 2022 39 minutes ago, jen and mark said: When dry, what do you recommend for sealing the PB prior to painting? mist coat? PVA? expensive primer? None of those things! High opacity Matt white emulsion, a couple of coats, and then sand that down to a finish. 1
PeterW Posted October 16, 2022 Posted October 16, 2022 4 hours ago, jen and mark said: When dry, what do you recommend for sealing the PB prior to painting? mist coat? PVA? expensive primer? Super Leytex paint - its what its designed for.
jen and mark Posted October 17, 2022 Author Posted October 17, 2022 Could you use Contract Matt Emulsion? Its half the price!
