1 need 34 meters of 35 mil A cable
In the past I’ve used Screwfix for British cable
A friend has said that Many of the wholesalers and online are selling Turkish c##p and I’ll have no idea till I’ve bought it
Can anyone recommend a seller that stocks Prism or Doncaster
5 minutes ago, PeterW said:
2 core or 3 core ..? I use these guys now as the old supplier I had closed down
https://armouredcable.net/armoured-cable/35mm/35mm-2-core-armoured-cable.html
Why 35mm out of interest as that’s good for 180A - 25mm would do 140A which is more than adequate for a house and the voltage drop is 6.5v on that distance. It would save you £100..
Thanks Peter
It’s going to run 35 meters from the meter box to the consumer unit
The Electrician that will terminate it said possibly 25 mil But safer for 35
3 minutes ago, nod said:
Thanks Peter
3 core
34 minutes ago, PeterW said:
3 core 35mmis a monster cable - not ducting it and hoping to pull it is he ..??
I put in a 40 mil duct for the mains as normal Before I found out they would only bring the supply to the front boundary and would need a much thicker cable
Luckily I laid a 70 mil smooth walled duct next it for gates and lights So I will have to get a rope in that tomorrow and pull the cable through myself Before I lay the base
I pulled through 25mm 5-core 30m through 100mm twin wall. That stuff is ******* heavy!
I also bought a cobra from Amazon which has been invaluable.
Also learnt a valuable lesson. Make sure you remove the draw cord that comes in the duct before pulling cables through as otherwise it bunches up and causes blockages. That was a painful lesson.
44 minutes ago, TonyT said:
Use the draw cord that’s in the duct to pull in a blue rope, then tie the cable and another blue rope onto it and pull
if only I was that clever
A 50mm is nowhere near as big as I thought it would be.
35mm only marginally bigger than 25mm tbh.
