Tetrarch Posted September 12, 2022 Share Posted September 12, 2022 I laid an Amtico floor about 20 years ago and whilst I was quite pleased with the outcome I did have a visible line across the bathroom where the plywood sheets were butt-joined I'm in a new house with a new bathroom planned, and whilst I now consider Amtico overpriced I'm looking to lay LVT again, but definitely with a T&G sub-floor of some sort. My thoughts are that 22mm T&G ply would be the bees-knees in terms of spec for the floor . The hierarchy is probably: A. 22mm T&G plywood B. 18mm T&G plywood? C. 22mm T&G chipboard? D. 18mm T&G chipboard Does anyone have any experience or recommendations that they would care to share? Regards Tet Link to comment Share on other sites More sharing options...
joe90 Posted September 12, 2022 Share Posted September 12, 2022 I laid LVT on moisture proof 22mm chipboard T@G and no problems at all, sold as a rock. Link to comment Share on other sites More sharing options...
markc Posted September 12, 2022 Share Posted September 12, 2022 (edited) T&G ply isn’t as good as T&G chip because the ply layers can leave longitudinal grain only allowing tongues especially to break off easily. As above MR flooring chip with glued joints is bullet proof Edited September 12, 2022 by markc 1 Link to comment Share on other sites More sharing options...
Tetrarch Posted September 12, 2022 Author Share Posted September 12, 2022 Thank you both for your comments. I had assumed that becuase ply seemed to almost a requirement for the shower tray that it would be a superior product for the remainder of the floor. Is any filling required or even recommended for the joints prior to LVT or are they good enough as are? (You can tell that the previous experience really burns - 20 years of looking at an unremediable DIY mistake in a premium product) Regards Tet Link to comment Share on other sites More sharing options...
joe90 Posted September 12, 2022 Share Posted September 12, 2022 (edited) Well my chipboard floor was new, all joints filled with d4 glue as they should be so no filling required (and the shower tray was installed on the chipboard). Ply is usually used to even out a floor, say floorboards which will curl, move etc. Edited September 12, 2022 by joe90 Link to comment Share on other sites More sharing options...
Tetrarch Posted September 13, 2022 Author Share Posted September 13, 2022 I can see that my previous comment might easily be misinterpreted. Following your comments I will now be using glued 22mm chipboard with PW under the shower tray, cut to exact dimensions and appropriately noggined Thanks and regards Tet Link to comment Share on other sites More sharing options...
Jimbo37 Posted November 10, 2023 Share Posted November 10, 2023 @joe90 @Tetrarch can either of you recall what adhesive you used to stick your LVT to chipboard Link to comment Share on other sites More sharing options...
Tetrarch Posted November 10, 2023 Author Share Posted November 10, 2023 I'm afraid that I can't remember. I bought it from the same place that I bought the Amtico, but either I bought it by post and/or my email account doesn't go back far enough. I do remember that it was highly potent stuff and I had a raging headache after doing just 5 sq m Regards Tet 1 Link to comment Share on other sites More sharing options...
joe90 Posted November 10, 2023 Share Posted November 10, 2023 1 hour ago, Jimbo37 said: @joe90 @Tetrarch can either of you recall what adhesive you used to stick your LVT to chipboard No sorry but supplied by the LVT supplier as recommended. 1 1 Link to comment Share on other sites More sharing options...
Jimbo37 Posted November 16, 2023 Share Posted November 16, 2023 My glued/interlocked chipboard has 8mm soundproofing mat underneath, that will compress to about 4mm as you walk on it. Room sizes are about 3m to 4m. I want to lay LVT, glued or click, but wonder if that that is risky with the 4mm compression - any thoughts? Link to comment Share on other sites More sharing options...
