AlanUK Posted September 2, 2022 Share Posted September 2, 2022 Hi, I'm plasterboarding my garage, and want to plaster to a wooden window surround, and to a breeze-block wall, as shown in the pictures. How do I do that without getting them all messy. Is there a special bead that is used, or masking tape, or what? Thanks. Link to comment Share on other sites More sharing options...
bassanclan Posted September 2, 2022 Share Posted September 2, 2022 https://superiorrendersupplies.co.uk/blue-dolphin-exterior-rough-surface-masking-tape-(orange)-48mm-x-50m~225 For the brickwork and low tack masking for the window wood. Also consider cling film for wider window protection. Remove the next day Link to comment Share on other sites More sharing options...
AlanUK Posted September 2, 2022 Author Share Posted September 2, 2022 Interesting, thanks. What about when it comes to removal, and there is plaster stuck to the tape - when the tape is removed won't it pull plaster with it, leading to a broken edge? Link to comment Share on other sites More sharing options...
twice round the block Posted September 2, 2022 Share Posted September 2, 2022 Stop end beading 1 Link to comment Share on other sites More sharing options...
bassanclan Posted September 2, 2022 Share Posted September 2, 2022 Or run a knife along the line you want Link to comment Share on other sites More sharing options...
Gus Potter Posted September 3, 2022 Share Posted September 3, 2022 You can use a thin 2.0mm plaster stop bead to create a shaddow gap. You let it all settle down shrink etc and then mastic to air seal if need be. Have done this on my own house but did the plastering myself as it is really time consuming to set up the bead acurately. Could not afford it otherwise. Have to say.. needed a bit of time off after (sore body) so hat off to @nod 1 Link to comment Share on other sites More sharing options...
jfb Posted September 3, 2022 Share Posted September 3, 2022 What finish have you got on the breezeblock? if plasterboard you want that on first and then a bit of scrim tape joining the ceiling skim to the wall. Same if rendering. Link to comment Share on other sites More sharing options...
AlanUK Posted September 5, 2022 Author Share Posted September 5, 2022 On 03/09/2022 at 10:05, jfb said: What finish have you got on the breezeblock? if plasterboard you want that on first and then a bit of scrim tape joining the ceiling skim to the wall. Same if rendering. Initially its just going to be painted. I guess it's not too much of a problem there because I'll be painting after the plastering, so I'll cover up any staining. I may render or plasterboard it later. Link to comment Share on other sites More sharing options...
