GandyP Posted August 26, 2022 Posted August 26, 2022 I had a problem with Hep2O pipe inserts remaining in the fitting even when demounting the pipe using the Hep2O tool. Some times I have re inserted the Hep2O and got lucky. When all else fails I use a piece of old grey Wavin Polypipe that I keep in my garage ( Yes I am a hoarder) and this always seems to do the trick. Polypipe is softer than Hep2O pipe and the insert shark teeth sink easily into the internal bore of Polypipe. Before I push Hep2O inserts into the pipe I use a small screwdriver to lift the teeth up a bit more so they are more likely to catch the internal bore. 1
joe90 Posted August 26, 2022 Posted August 26, 2022 Yes I have suffered this, best to get it right first time 😱
Russell griffiths Posted August 27, 2022 Posted August 27, 2022 I have had this, I normally de mount both sides and chuck the fitting, I’m not risking catching the rubber o ring to save a £2 fitting. 1
Pocster Posted August 27, 2022 Posted August 27, 2022 (edited) Experienced this also . Usually get pliers and bust / pull the sleeve out the fitting . If I’m not in the mood to fanny around i throw the fitting . Edited August 27, 2022 by pocster
dpmiller Posted August 27, 2022 Posted August 27, 2022 yep, had this too. Shame, as some other brands can be unscrewed to make removal easier   /ducks
GandyP Posted August 28, 2022 Author Posted August 28, 2022 A clarification of my inital post. I use a piece of 22mm polypipe and push it on to the stuck insert then recover the insert without damaging the fitting O-ring. It also pays to lift the barbs on the stuck insert prior to removing it. Saves the Fitting,Fuel and a visit to the plumbers merchant.
