jack hammer Posted June 10, 2017 Posted June 10, 2017 Hi all, my first post here. Just need some guidance on what length of nail plug to use! I want to fix lengths of timber battens (24mm x 48mm x 3000mm) to an aerated concrete block outer wall. 24mm is the depth of the batten. (I´ll use 24 x 100mm at the corners) I intend to use fischer N 8 x 80 nail plugs, at approx 50cm spacings along the length. I´m going to fix lightweight aluminium cladding to these battens. Am i going too short here or do i need a bigger/longer plug? (8 x 100 ?!) Thanks in advance all,
Construction Channel Posted June 10, 2017 Posted June 10, 2017 Hi Jack and welcome how thick are the blocks? aerated blocks are notorious for giving a poor fixing, if you are using nailable plugs I would go as deep as possible, personally, i would consider using concrete screws although they will be slower and dearer, i would be more confident that it got a hold . HTH Ed
Russell griffiths Posted June 10, 2017 Posted June 10, 2017 I don't think length is the critical thing here it is finding a good plug that works with your blocks, some of the lighter aircrete blocks can be a sod to get a good fixing in, I think doing some tests on some spare blocks would be the first thing I would do before buying a few hundred plugs. I remember really struggling to get a good fixing in aircrete, but we found a plug that screwed itself into a twisted little mess that never shifted.
Nickfromwales Posted June 10, 2017 Posted June 10, 2017 I just drill excessively deep and insert regular red plugs. I then put a No.12 screw into the plug so it over expands. A bead of expanding foam ( lowxexpansion pink grip board fix ) along the full length prior to fitting works wonders. I'd never for one second use hammer fixings for this. Massively unreliable in aerated block. . And welcome to the forum .
jack hammer Posted June 10, 2017 Author Posted June 10, 2017 Thanks so far all. The thickness of the wall, inner to outer is 30cm. I´ve done a few tests to one side and used a 7mm bit so that the 8mm plugs had a tighter fit. Seemed to work OK !! Strangely ( irritatingly!) i´ve seen identical looking nail plugs from other manufacturers where they state that they aren´t suitable for aerated concrete, and these from Fischer apparently are! There are some out there solely for aerated blocks but they´re about 3 times the price! I am tempted ( as Nickfromwales says) to go for standard plugs, and just do it the slower, but safer, way!
PeterW Posted June 10, 2017 Posted June 10, 2017 I won't use anything else than Fischer plugs now - they are worth the small extra price to pay as they work first time.
Nickfromwales Posted June 10, 2017 Posted June 10, 2017 Hitting the next fixing loosens the last imo so 'knock-in' fixings are a no go for me. ??
jack hammer Posted June 13, 2017 Author Posted June 13, 2017 Spoke to a local roofer yesterday and he also says nail plugs in aerated concrete are just not to be depended on! I´m going to go with Fischer universal fixings plugs and decent screws. It´ll take a bit longer but at least i´ll know i´m safe! As Nickfrom says, hitting the next nail plug, i can see that loosening everything back off again!!
