JohnBishop Posted July 24, 2022 Posted July 24, 2022 Hi, I have inherited this kitchen tap and the problem I have I don't know how to terminate this 3rd "filtered water" pipe. https://i.ibb.co/J3J8Rcf/brita-filter.jpg If I use a tap adapter/aerator then water leaks through it from the tap. Please advise.
ProDave Posted July 24, 2022 Posted July 24, 2022 Find out what size it is and buy a blank plug. This is a random example for an 8mm plug https://www.ebay.co.uk/p/2211717247
JohnBishop Posted July 24, 2022 Author Posted July 24, 2022 from my measurement it looks like it is 4.3mm wide so I reckon I need like 5mm plug.
JohnBishop Posted July 24, 2022 Author Posted July 24, 2022 7 minutes ago, dpmiller said: 8mm OD if it's the same as mine. This is Brita Paini. The pipe is like 8mm but the plug I need I think would be 5mm.
dpmiller Posted July 25, 2022 Posted July 25, 2022 if it's 8mm pipe, then either an 8mm stop end for the pipe or a plug for the pushfit. If in doubt, remove the pushfit installed for a closer look at it, just in case an 8-6 reducer has been fitted. It's definitely metric tho, as imperial JG fittings are beige. 1
Conor Posted July 25, 2022 Posted July 25, 2022 8 hours ago, JohnBishop said: This is Brita Paini. The pipe is like 8mm but the plug I need I think would be 5mm. Pipes are generally known by their outside diameter, same for the fittings. 1
ProDave Posted July 25, 2022 Posted July 25, 2022 1 hour ago, Conor said: Pipes are generally known by their outside diameter, same for the fittings. In this case it's a straight couple connected to the pipe, so the plug required will be the OD of the pipe. If you can uncouple the straight coupling (push the end in and it should release the barb) then take the fitting with you to get the right sized plug. 1
