GrantMcscott Posted June 3, 2022 Posted June 3, 2022 Hi Started putting on my capping board today and have noticed and issue which I think ios due to the roof not being put on straight. This part of the house does not have any soffits, As you can see from the photos it starts off with no soffits but at one point the gap goes up to 60mm. Any suggestions on how to fix this or if it can be fixed. I can not pack them out and put a soffit on as that would make the windows look funny.
GrantMcscott Posted June 3, 2022 Author Posted June 3, 2022 7 minutes ago, SuperJohnG said: What's the final finish? It is render on the block
GrantMcscott Posted June 4, 2022 Author Posted June 4, 2022 I was thinking about trimming back the rafter tail 30mm or so to correct it but do not know what impact that will have on the tiled roof.
ProDave Posted June 4, 2022 Posted June 4, 2022 Is your concern the gap between the bottom of the capping and the wall? If so take off the existing bit of weathered OSB strip and fit something thinner instead like a fresh bit of 9mm OSB would that be enough?
GrantMcscott Posted June 4, 2022 Author Posted June 4, 2022 2 hours ago, ProDave said: Is your concern the gap between the bottom of the capping and the wall? If so take off the existing bit of weathered OSB strip and fit something thinner instead like a fresh bit of 9mm OSB would that be enough? Hi I stripped it off and for some reason it was packed out at one end causing the issue. Trimmed it back with the multi tool and it is sorte. Glad I did strip it off as there was wool insulation behind socking wet. Panic over nothing as so much has went wrong with my build.
