cwr Posted May 11, 2022 Posted May 11, 2022 Some guttering appeared on our build today, despite the rendering not being finished. Is that normal/ok? There are two coats of base layer on but still to have the final Weber thin (top) coat applied.
Russdl Posted May 11, 2022 Posted May 11, 2022 I’d say ‘no’. The top coat needs to go behind the gutter as well. Perhaps they’ll take the gutter down when they render. Maybe it’s just a ‘test fit’ of the gutter...
Ronan 1 Posted May 12, 2022 Posted May 12, 2022 Gutters often go on so if it rains during or shortly after plastering the water from the roof doesn't destroy the plaster running down it in lines, usually they will put a lenght of pipe up against the outlet for the down pipe to let the water captured down to the ground away from the walls
Conor Posted May 12, 2022 Posted May 12, 2022 (edited) It's to keep the wall dry for the top coat. Our renderers did the soffits and fascias, we put on guttering, then they came back and did the walls. Edited May 12, 2022 by Conor
Mr Punter Posted May 12, 2022 Posted May 12, 2022 You can get polythene temporary downpipes as well. They tend to flap around when it is windy though.
cwr Posted May 12, 2022 Author Posted May 12, 2022 In fairness the guys are being picky with the weather about when to render (plenty to plaster on the inside on rainey days). So if there's any splashing from gutter to behind it then it'll not matter there's no top coat?
