ProDave Posted April 26, 2022 Share Posted April 26, 2022 An interesting flyer popped through the door today, sent to all houses in the locality. Just over the hill from here, on the way into town, they are starting the initial planning of a grid scale battery storage plant. The proposal is to take over a field next to a local substation, and fill it with battery storage. Details are scarce at the moment but the companies website talks of short term storage, up to 4 hours, to charge at times of surplus renewable energy and discharge at peak demand times. It won't affect us, it will be well out of site and probably not very visible either from the road as the substation it will be adjacent to is down in a dip. Someone thinks it is now viable to spend a lot of money on a lot of batteries. Link to comment Share on other sites More sharing options...
SteamyTea Posted April 26, 2022 Share Posted April 26, 2022 On 26/04/2022 at 16:25, ProDave said: Someone thinks it is now viable to spend a lot of money on a lot of batteries. Expand If you look on the Elexon website you can see how cheap excess Scottish wind power is, and how expensive emergency extra generation is. Large scale storage is much cheaper than domestic level, though I do think if most houses had 1 kWh of storage that could deliver at 3 kW of power, that would be very useful. It would be owned by the power companies, rather than the householder. That way people cannot tinker with it. 1 Link to comment Share on other sites More sharing options...
Dillsue Posted April 26, 2022 Share Posted April 26, 2022 On 26/04/2022 at 16:25, ProDave said: It won't affect us Expand With a very large quantity of potentially toxic chemicals stored near me Id be wanting to know all the measures taken to deal with fire, chemical leaks etc. I know very little about battery chemistry but I doubt the contents are something you want drifting in the air or leaching into local ground water. 1 Link to comment Share on other sites More sharing options...
Roger440 Posted April 26, 2022 Share Posted April 26, 2022 On 26/04/2022 at 17:12, Dillsue said: With a very large quantity of potentially toxic chemicals stored near me Id be wanting to know all the measures taken to deal with fire, chemical leaks etc. I know very little about battery chemistry but I doubt the contents are something you want drifting in the air or leaching into local ground water. Expand No one seems to care about litium leaking into the environment. Id go so far as to say its going to be an environmental disaster many years from now. All the batteries from phones, laptops and other consumer electrical stuff just goes straight to landfill. Eventually thats going to end up in the ground and our water. Link to comment Share on other sites More sharing options...
ProDave Posted April 26, 2022 Author Share Posted April 26, 2022 On 26/04/2022 at 17:12, Dillsue said: With a very large quantity of potentially toxic chemicals stored near me Id be wanting to know all the measures taken to deal with fire, chemical leaks etc. I know very little about battery chemistry but I doubt the contents are something you want drifting in the air or leaching into local ground water. Expand It's about a mile from us, over the brow of a hill, and not upwind (prevailing wind) of us. In fact there is only one house close to it, and that is a croft. I would not be happy if I was that croft, but it would not surprise me if it was their land the plant will be on, and they will be adequately compensated so they don't worry about it. Link to comment Share on other sites More sharing options...
GavH Posted April 27, 2022 Share Posted April 27, 2022 It might not be an electrical battery. We had a proposal in Caithness, for a mechanical CO2 battery to be trialled. Use spare electricity to liquify CO2 for the air and store in Tanks. Then at a later time expand through turbines to generate electricity. Link to comment Share on other sites More sharing options...
SteamyTea Posted April 27, 2022 Share Posted April 27, 2022 (edited) On 27/04/2022 at 08:45, GavH said: CO2 Expand Seems an odd choice of gas. I think CO2 is only liquid in a very narrow pressure/temperature band, the critical point. Though for CO2 that is a reasonable 304K and 7.4 MPa, so maybe that is the reason. Easy to store at 30°C and 7.3 Atmosphere. Lightweight kit. Edit: Whoops, DuckDuckGo saw MPa as mPa, so 1073 PSI, or 73 Atms. Still not extreme. Edited April 27, 2022 by SteamyTea Link to comment Share on other sites More sharing options...
ProDave Posted April 27, 2022 Author Share Posted April 27, 2022 It sounds like batteries to me. the flyer says: "It would comprise of a compound of electrical equipment, battery units, transformers, store and energy meter building" There was one company on the news recently building a trial storage plant that literally wound a stack of concrete blocks to the top of a tower to store energy then let them back down again to generate energy. Link to comment Share on other sites More sharing options...
SteamyTea Posted April 27, 2022 Share Posted April 27, 2022 On 27/04/2022 at 11:40, ProDave said: There was one company on the news recently building a trial storage plant that literally wound a stack of concrete blocks to the top of a tower to store energy then let them back down again to generate energy. Expand Why not just pump water up and down an old water tower. Lower embodied carbon footprint. 1 Link to comment Share on other sites More sharing options...
markc Posted April 27, 2022 Share Posted April 27, 2022 On 27/04/2022 at 13:13, SteamyTea said: Why not just pump water up and down an old water tower. Lower embodied carbon footprint. Expand Energy density, they are building towers of dense concrete or steel blocks and a automatic crane grabs and places the blocks or grabs and lowers them to the floor. You would need a massive water tower to hold an equivalent mass and height difference. They are also looking at deep shaft variants Link to comment Share on other sites More sharing options...
SteamyTea Posted April 27, 2022 Share Posted April 27, 2022 Concrete and steel are about 3 times the density of water. Water though, can easily run downhill, in a suitable pipe, and any angle. Link to comment Share on other sites More sharing options...
