Cracks to worry about?
JamesB
2 hours ago, JamesB said:
should I be worried about these cracks
Keep an eye on them and if they get no worse it should be ok.
If that wall was going to crack then these would be the expected locations.
Most/ all walls crack but it is hardily noticeable. The white render emphasises it.
How wide are they? (pound coin is the definitive indicator)
However, assuming the walls are masonry, I would expect the cracks to follow the shapes of bricks/blocks/stones.
What do you know about the construction, and if these are old or getting bigger?
Nothing lost informing your insurance company. Keep a log of photos.
I like monitoring either with brass screws and vernier gauge or proprietary movement monitors, this is best done monthly over two years then make decisions
