Arnold9801 Posted March 15, 2022 Posted March 15, 2022 My large delivery of Actis Hybris is being delivered on Saturday and I'm trying to no avail to locate the correct saw to cut it. Can anyone advise me on where they're available as they seem ever so scarce? Regards
markc Posted March 15, 2022 Posted March 15, 2022 Hi, I would use a cheap wood saw if cutting while still rolled and a large knife for fiddly bits. assuming this is the foam honeycomb insulation I’m thinking about
Arnold9801 Posted March 15, 2022 Author Posted March 15, 2022 1 hour ago, markc said: Hi, I would use a cheap wood saw if cutting while still rolled and a large knife for fiddly bits. assuming this is the foam honeycomb insulation I’m thinking about It's the expandable honeycomb. I'm thinking of making one from an old saw. 1
SuperPav Posted March 19, 2022 Posted March 19, 2022 Never worked with that, but I've found either a 14-15tpi plastic handsaw or a serrated knife the best for most types of insulation. The plastic saw is much more fine toothed than a wood saw and so catches much less. Don't know how much of an issue this is with the honeycomb stuff though. https://amzn.to/3igUBDr https://www.screwfix.com/p/bahco-15tpi-wood-toolbox-saw-14-355mm-/44210?tc=AL4&ds_kid=92700055262507126&ds_rl=1244066&gclid=CjwKCAjw_tWRBhAwEiwALxFPocvzzJ3MAdsY88RVriAsTbjBFGhYmHCliJla_RE1mj2IjSCc7YP-BBoCMJEQAvD_BwE&gclsrc=aw.ds
JohnMo Posted March 19, 2022 Posted March 19, 2022 The instructions state. "HYBRIS can be easily cut with an insulation saw, standard hand saw or an electric alligator saw if preferred" Remember you need a 15-20mm air gap either side of the insulation to get the claimed performance
SteamyTea Posted March 20, 2022 Posted March 20, 2022 On 15/03/2022 at 08:09, Arnold9801 said: Actis Hybris I used to use an aluminium honeycomb and a high temperature composite to strengthen and thermally insulate steam pipework. Worked amazingly well considering the thermal conductivity of aluminium. Then changed to a Nomex honeycomb. Could build a whole house out of that as it is fireproof and amazingly strong.
