We originally wanted engineered timber floors and have set our door thresholds, kitchen gables etc 20mm above the screed. The reality of a young child and all the water, mud, stones, and generall abuse that comes with it, has changed our minds to laminate.
Most seem to he 8-12mm thick, some 14mm. We'd need to get a total thickness of 18mm or else we'll be off at our front door and bi-folds.
5mm wood fibre would get us close if we went for 14mm laminate. Could this be double up if we went for a thinner laminate? Or would it be too soft?
https://www.diy.com/departments/diall-5mm-wood-fibre-laminate-solid-wood-flooring-underlay-panels-pack-of-15/1520621_BQ.prd
(Above as an example only)
8 minutes ago, Mr Punter said:
Porcelain tiles are very hard wearing and they do wood type planks.
Percelain is also very hard on little heads ?
Have you considered cork floor underlay? This is available in mm steps from 2 - 10mm in rolls. You can see these at spduk.co.uk. I recently bought 100m2 of the stuff from corkfloor.co.uk at a great price but you'd need to speak to them on the phone for thicker than 2mm rolls.
I have just used some of the 5mm wood fibre stuff from screwfix, really impressed with it for the price. I can’t see any problem doubling it up as it is quite dense and will not squash under a distributed load like laminate
