I've got to start thinking about my suspended ceiling on the underground mega dungeon.
Current 'ceiling' is beam and block or just concrete.
I can't seem to find any details about the minimum distance the suspended has to be from the existing. I *recall* from somewhere 100mm. That correct?
We are planning recessed lighting. But again as modern recessed lights tend to generate very little heat and are slimmer ( plus also zero timber i.e flammable above ) then perhaps I need not worry?
Cheers
No regulation on what a suspended ceiling void needs to be. You can have it 20mm if you want. It's about what size do you need to hide the services. If you've 100mm waste pipe then it's probably going to be 130mm or so to allow for the pipe and fall.
23 minutes ago, Thorfun said:
I'll have this very same question for my mega dungeon in the future so thank you @pocster for posting it and @Dudda for answering it! ?
One thing you should be aware of as I've been told by all suspended ceiling suppliers - it will look like a Swindon Office block ceiling ....
What are your dungeons dimensions? - better not be bigger than mine otherwise I shall add an underground extension!
Edited by pocster
errr....about 115m2
8 minutes ago, Thorfun said:
errr....about 115m2
FFS mine 98m2!!!
BOLLOCKS! - going to measure it accurately later.
I AM DUNGEON KING!
Just now, pocster said:
FFS mine 98m2!!!
I AM DUNGEON KING!
you are SMALL dungeon King. ?
and remember, no matter what she says, size does matter.
(expletive deleted) THAT! - Measuring it now!
Do it in metal frame, then plasterboard as normal.  Just like a timber joisted ceiling but with fewer cracks.
HMMMM! 92m2
But that's allowing for finished wall to finished wall. Bet @Thorfun is cheating and using just floor area.
I also have my dungeon courtyard - I should add that in really; which is 24m2
So total is 116m2 - funny how I win by 1m2 - my measuring though is rather "subjective" - anyway ... I WIN!
Can't have plasterboard ceiling. Too much of a PITA . Also I want access to everything everywhere - because of the eclectic layout..... ?
13 minutes ago, pocster said:
HMMMM! 92m2
oh! we're INCLUDING the dungeon courtyard then are we?
in that case, I need to add an extra 19m2 so I'm now up to 134m2
<doing the happy dance>
Ffs !
Lets do it by volume . What’s your floor to ceiling height ?
4 minutes ago, pocster said:
Ffs !
just been down to measure.....3.075m
that's from proposed FFL to underside of beams. the screed is being laid Monday so I've subtracted that thickness (50mm) and the LVT thickness (10mm) from the current figure of 3.135m.
do I win some walk-on-glazing?
Ffs !
Rubbish game anyway !
You win Zoots heating system
Just put access panels where you need them.  The suspended ceiling tiles look pony.
Ffs !
You chose the wrong opponent for basement top trumps.
Our first floor is beam and block. The beam supplier provided some metal clips to hold battens to the underside of the beams. I think they were 22mm ish deep.
So the void under beams was just the batten depth 22mm.  Under the blocks the depth available for downlights was 50+22+12= 84 or 85mm ish.
Back then that was marginal for fire and sound rated GU10 style downlight housings but shouldn't be an issue for LED these days.
Edited by Temp
No , no , no . If you could see what I can see you’d understand. I could put an access panel every 1m I suppose .
