Conor Posted January 30, 2022 Posted January 30, 2022 Our screed moisture level is still too high to put down wooden floors - and we're moving in tomorrow. Would like to paint on something like watered down PVA to keep the dust down but still allow the screed to dry. Any reccomendations or advice? It's a cement based liquid screed.
Jenki Posted January 30, 2022 Posted January 30, 2022 I don't think you want to seal it, as the moisture still needs to escape, I think you can use a concrete stabilising solution, but you need to check with the screed manufacturer for suitability https://www.google.com/aclk?sa=L&ai=DChcSEwj5uKbbhtn1AhVK1O0KHYnpDtoYABALGgJkZw&ae=2&sig=AOD64_37KuEhO7wsYK2X51Rj0uk89Rno1w&ctype=5&q=&ved=2ahUKEwigzpzbhtn1AhUPecAKHV1KBFgQ9aACegQIARBV&adurl=
Adsibob Posted January 30, 2022 Posted January 30, 2022 @Conor when was it poured and how thick is it?
dpmiller Posted January 30, 2022 Posted January 30, 2022 Sandy is just in the process of sealing all ours at the moment with the Larsen pink Acrylic primer. I'd done the floors that I'd already tiled with it, as I'm using their tile adhesive... The MIs say a single 50/50 coat is permeable but you could give Larsen Technical a call for confirmation
