When specifying new-build windows to meet building standards, do inspectors just focus on the manufacturer's quoted glazing U value or do inspectors want to see a calculation of a combined U value for glazing plus frame?
In my case I am talking about wooden sash windows fitted with high spec sealed glazing quoted as:
Glazing: D.G.U 24mm (4mm annealed - 16mm gap - 4mm soft coat Low E annealed)
 Glaze gap: Argon gas filled: centre pane U value = 1.1W/m2k
 Glazing spacer bar: TECHNOFORM "T.G.I" warm edge
Whole window Uw value will go into the SAP calculations and that will pass or fail building regs.
Manufacturer should publish Uw values.
Ok thanks both, not what I wanted to hear.
One bit of good news is that wooden windows only have to meet a U value of 1.6. I suppose I could try to argue that if the glazing has a U value of 1.1 the frame would gave to perform very poorly to drag the overall U up past 1.6
I will contact the importer of these Baltic sash window to see if they can provide a whole frame U score.
