Hey
I have a 100m run from site kiosk to the house. It will be into a temp meter box for a while. Along the way it crosses a boundary where a wall will be built later.
what covering / duct etc do I need under the wall area ? Normal depth and warning tape etc will be applied.
Min 750mm deep, use 75mm corrugated black duct for at least 1m either side and make sure it’s got the proper tape across the whole area. Better would be to cast the footing for the wall so it’s visible from the outset or at least a 2m section where this is.
100m is a long run though - will this become permanent ..?
Yes tape etc all in hand.
100m it is … can’t move the source any closer ! That’s why it’s 50mm. Ouch. ££
5 minutes ago, IanMcP said:
CEF are £14 per metre. Let me know if you know somewhere cheaper
Cleveland cables. But it was last year so might have been a bit cheaper.
it was about £9.60 plus vat a metre.
Why not go 3 phase at that point and go 4x16 and utilize the phases differently ..?? Easier than chucking 50mm around and cheaper too.
