GrantMcscott Posted January 22, 2022 Posted January 22, 2022 Hi My doors are leaking between the Dpc and the insulation they are sitting on. They are always wet so can not get tape to stick as it is never dry this time of year. Can any one recommend how to seal
dpmiller Posted January 22, 2022 Posted January 22, 2022 any of the "works underwater" hybrid sealants?
markc Posted January 23, 2022 Posted January 23, 2022 35 minutes ago, tonyshouse said: Where oh where is the sill? +1 to this, any water landing on the brick will end up inside if the brick leans inwards or will be pulled in by capillary action. you need a fill to take drips clear of the brick 1
GrantMcscott Posted January 24, 2022 Author Posted January 24, 2022 22 hours ago, markc said: +1 to this, any water landing on the brick will end up inside if the brick leans inwards or will be pulled in by capillary action. you need a fill to take drips clear of the brick There will be slab up to the door when finished running away from the door. Have used some CT1 to see if that seals it up for now until slab is laid and drain put in
