Hello :)
I had some good advice here when we were planning our now-complete house and I am back for more! The next step is a very small ancillary building connected to the house services, to provide additional accommodation (bed, kitchenette, bathroom). I was advised this morning that if the structure is smaller than a certain size then the only building control involvement is with regard to connecting to the septic tank. Can anyone elaborate on this please or point me to a good source?
I had resigned myself to going for a mobile shepherd's hut type building as I believed I would otherwise have to meet criteria for minimum distances and suchlike which would mean engaging an architect. This provides a glimmer of hope. I was thinking along the lines of a Sweeny's bothy kind of thing http://www.eiggtime.com/sweeneys-bothy in terms of being basic/rustic.
As I understand it I do not need planning permission for this if it is in the curtilage of the building and for our own use...
Thanks in advance!
1 hour ago, Grian said:
Hello :)
Thanks in advance!
You don't need planning for small buildings (terms & conditions apply) presuming they're for storage, den/man cave/ home office etc but if it has bedroom, kitchenette, etc you will no matter how small it it. Anything that can be used as a self contained unit, granny flat, etc. needs planning.
This is the rule where I am but it will depend on your local planning laws. Where are you based?
Edited by Dudda
You can build a small single storey building under the "caravan" regulations.  To legally be a caravan it does not need to be on wheels but needs to me moveable in some way that can include picking it up with a crane and lifting it onto a low loader.
Such a building is exempt from building control except for any drainage system that it is connected to.
It might still need planning permission, that is separate.
  • Like 2
So, it seems the key bit I was missing re exemption from Building Control is that the structure must be moveable (in a maximum of two sections, I gleaned elsewhere here) as well as single storey and small as per caravan regulations.
And I am reminded, thanks, that I would need planning permission if it had it's own facilities for eating and washing, even if it were for my own household use.
Thank you!!
