GrantMcscott Posted January 19, 2022 Posted January 19, 2022 Hi Can anyone recommend a water treatment company that can design and supply a water treatment filtration system for my private water supply. I have had the water tested and have the issues with metals in the water which will need to be removed before the UV filter will work effectively. Also need the water softned and particle filter Thanks
GrantMcscott Posted January 19, 2022 Author Posted January 19, 2022 2 minutes ago, JohnMo said: Where are you in the country? Hi I am in East Ayrshire Scotland
jamieled Posted January 19, 2022 Posted January 19, 2022 I used the highland pump centre for supply of my filters. They double checked my design using the sampling results. They work all over scotland I think. Otherwise if you want design, supply and install, highwater seem to do most of the work around us. 1
TonyT Posted January 19, 2022 Posted January 19, 2022 DMA https://www.dmacanyon.co.uk/wp/ used them for tank cleaning and disinfection, chemical dosing, large tank installation, L8 risk assessment for 10 years good service and I’m in fife they are near Glasgow 1
