Hi,
I have fitted metal herringbone struts to the truss joists and the strut metal plus the nail head means there is around 3 to 4mm below the joist.will this affect the fitting of the plasterboard
58 minutes ago, Mr Punter said:
you could pack the joists with hardboard
Hardboard is a great packer, I use it a lot, known thickness and can be used in multiples. Or you could counter batten the opposite way between metal pieces or use sound bars (which I wished I had used) to increase sound insulation between floors.
The resilient bars are a good call.  I also wish I used them.  No point for the OP unless they are attic trusses.
I had to gauge out a few bits of plasterboard and found a quick and easy way. Grab the cheapest router you can, aldi and lidl do em. Set it at the few mil depth you need and it makes a quick and easy way to take out some of the plasterboard. Bit dusty mind, but work it does
