ToughButterCup Posted December 9, 2021 Posted December 9, 2021 Calling all door trimmers! Calling all door trimmers! Carpets fitted yesterday! Whoooppppeee . (Now I need to remove my boots going upstairs or else it's ☠️ by the most painful method available to her) Today's challenge is to trim two doors to size. Here's the spec for one of them The lipping thickness for the bottom rail is 10mm . Because of the new carpets, I need to trim off a good deal more than that - roughly 20mm. The construction is wood or particle board. Can I trim the 20mm off and leave the bottom as particle board OR should I trim (say) 30mm off and make up a 10mm batten and glue and screw it to the bottom of the door? Thanks in anticipation .... (PS anyone know of some safety boots suitable for indoors (easy-on : easy-off) - already dropped the door on my stocking feet ?)
ProDave Posted December 9, 2021 Posted December 9, 2021 Can't help with the door trimming. A second new pair of slip on safety boots for "indoor use only"? I learned very early on when I went self employed to wear slip on safety boots, so much easier when you have to take them off in a customers house. but then most of the time I am working indoors I do so in my "working slippers" (old worn out pair that are a bit tatty)
Adrian Walker Posted December 9, 2021 Posted December 9, 2021 33 minutes ago, ToughButterCup said: (PS anyone know of some safety boots suitable for indoors (easy-on : easy-off) - already dropped the door on my stocking feet ?) What you need is SAFETY RIGGER BOOTS
ProDave Posted December 9, 2021 Posted December 9, 2021 These will do (serious suggestion) https://www.completesafetysupplies.co.uk/protective-footwear-c68/food-environment-wellingtons-shoes-c143/click-work-safety-slippers-steel-toe-cap-white-p1328 You get some interesting hits searching for "steel toe slippers" P.S Note to readers of this thread. Set your door frames high enough to allow for carpet and underlay right from the start (Sorry Ian)
ToughButterCup Posted December 9, 2021 Author Posted December 9, 2021 7 minutes ago, ProDave said: .... Set your door frames high enough to allow for carpet and underlay right from the start (Sorry Ian) No Dave you're not bluddee sorry. ? Typical sparky SOH. Revenge on its way. I recon for ab initio builders - no experience of building at all - building your own house is the building equivalent of doing PhD (doctorate) Oh, BTW, them Work Safety slippas is reeely cool
joe90 Posted December 9, 2021 Posted December 9, 2021 On the subject of doors, I trimmed one of mine into the particle board and just sealed it with coats of varnish, you never see it. If you plant on the bottom it will look different to the other edges so why bother? 1
