WWilts Posted November 24, 2021 Posted November 24, 2021 (edited) Timber first floor, cavity wall blocks inner leaf, brick or stone outer leaf. Question re lateral restraint straps. Currently lateral restraint straps are being inserted through 1:5 cement:sand mortar perpends, with little or no anchoring to the 7N aircrete blocks of the inner leaf. Will the mortar alone be strong enough to serve the purpose of the straps? Some 1:6 mortar is said to have 7N/mm2 compressive strength at 28 days. Still, seems a bit dicey. To insist or not insist, on anchoring the straps to blocks. That is the question. Edited November 24, 2021 by WWilts
Russell griffiths Posted November 24, 2021 Posted November 24, 2021 Has it not got a 90 degree turn on the end into the cavity. Many ways to do it. Some drill a hole in the block and put end in there some just hang the turned end into the cavity. But definitely not a straight tie just in a joint. Picture. 1
WWilts Posted November 24, 2021 Author Posted November 24, 2021 (edited) 2 minutes ago, Russell griffiths said: Has it not got a 90 degree turn on the end into the cavity. Yes. But instead of the vertical bit sitting against the block surface, it will sit against the perpend mortar. Is that sufficient? Edited November 24, 2021 by WWilts
Russell griffiths Posted November 24, 2021 Posted November 24, 2021 tbh The mortar is probably stronger than those blocks anyway. 1
