Loz Posted November 23, 2021 Posted November 23, 2021 Hi, Plumber was doing bathroom today and was plumbing in thermostatic valve for shower in copper, all looks good other than the pipe that comes out of the top and runs up into attic for rainfall shower head. As there was something in way pipe is running at an angle - probably about 5 degrees, hot and cold filled and no leak but could this cause a weak point further down the line or doesn't it matter ? Will be a tiled wall ultimately so a pain if ever leaked in future. Just looks weird as every other pipe goes straight into its housing other than this one and can't help feeling it should be straight. Guess only solution would be a couple of right angle bends close together - not sure of that would reduce flow at all as want max flow to the shower head or tp bend the pipe but bit late for that now as all hooked up. Any thoughts greatly appreciated. Many thanks, Lawrence
ProDave Posted November 23, 2021 Posted November 23, 2021 Picture? Are you sure he didn't put a small bend in the pipe? 1
Loz Posted November 24, 2021 Author Posted November 24, 2021 Here is picture of pipe coming out of top, there is a little bend but where exits valve is at a bit of an angle....
Iceverge Posted November 24, 2021 Posted November 24, 2021 If it has been pressure tested and doesn't leak now I'd say it's no more likely to leak than any of the other connections. It's hard to tell from the photo but I think the plumber has put a bend in the pipe. I think it's fine. 1
Nickfromwales Posted November 24, 2021 Posted November 24, 2021 It’s not the best pipe instal, but the compression joint ( and olive ) will have confirmed to grip and seal onto that without issue. I doubt you’ll have any problems tbh, but 2 mins with a pipe bender would have done this the world of good. I’m surprised at how many plumbers don’t own one, but some seem a bit scared of them. Either that or they simply cannot be bothered. 1
Loz Posted November 24, 2021 Author Posted November 24, 2021 Thanks both for replying, was hoping general opinion would be that it is okay, system has been filled so no leaks, was just concerned could be a weak point over time but sounds like will be fine to leave as is, I think there is a very slight bend in the pipe but could have probably benefitted from a bit more, Many thanks, Lawrence
