Hi,
We've just had a patio laid and we wondered what the best product was to seal it?
Can someone recommend something?
Thanks!
To add more detail, the patio consists of paver blocks and paver slabs (council) and is approximately 5m long by 2m wide. It's laid on a cement base and has been joint filled with kiln dried sand. I've cleaned it with brick cleaner and I'm now looking to put some sort of seal/waterproofer down to make the patio look finished
Need to know whether its concrete, porcelain or real stone.
Sealer isnt necessary on all, and in fact, isnt actually "necessary" on anything.
No matter how well sealed if you do decide to go that route, it'll always wear, and as such, will require maintenance if anything is applied.
Edited by Makeitstop
In my case concrete paving slab, home made (wet mix, vibrated).
I'm also wondering how useful a sealant would be on my garage floor to prevent water that drips off the car from soaking in.  Concrete has not had any treatment or paint applied and has been there five years.
If it doesn't look finished now, I can't see a sealer making the difference tbh.  What are you looking for from a sealer?
Sealing a garage floor is not a bad idea. It'll reduce dust and can also provide a level of priming for floor paint.
Externally though, and on concrete pavers, I'd say its largely a waste of time and money and may be one of those jobs you wish you hadn't started.
That's interesting. The patio is made of concrete council slab pavers and brick paving blocks. We were looking to seal to add waterproofing and give it a finished look
