Stratford eb20 log burner Please Help
Jblakes
Good afternoon,
I'm really struggling to keep this thing going with smokeless, plus get it upto temp. This fuels out central heating and we wake up to unburnt coal and fire out in morning.
Can somebody tell me if the eaay boost slider the primary air and should be left open with coal?
Also what is the job of the thermostat thing on the side? And how do i use it?
Kind regards
Welcome to THE forum for people like us! Someone will be along shorty to help I am sure Although I know a bit about steam locomotives I am not sure that experience will help however putting air in above the fire sounds like a no-no for over night running. If we want to keep a fire in over night, not a frequent occurrence, we tend to shut the damper, below the fire, right down to almost closed and if the wind blowing hard we close it down even more but avoiding shutting it completely. Locomotives don't have dampers above the fire. Unburnt coal sounds like a lack of air to keep it burning too much air and you will be left with ash and too little and you will be left with coal!
The general principle with a stove is you want air in at the bottom (primary air) when burning coal, and you want air in at the top (secondary air) for burning wood.  so once going in your case top vent shut, bottom vent open, and regulate it by opening or closing the bottom vent.
This stove has a thermostatic system, presumably (it does not say) it regulates the burn to regulate the water temperature?  If so then you need water flowing and the heat from it disappointed somewhere.  Otherwise could your problem be the water has reached set temperature, nothing is cooling the water down, so the stove is shutting itself down?
Most stoves with boilers like this are optimised for water heating, not room heating.
When I say "water" the stove only know about the water that flows in and out of it's back boiler. It does not know where it goes or what it is used for.
I only put that forward as a possible reason why it is shutting down that perhaps the water flowing out of it's back boiler has reached and staying at it's maximum temperature.
If the rads are only luke warm perhaps there is a blockage or water flow problem so they are not taking heat away from the stove properly.
When it is in that state with luke warm rads, is it possible to feel the temperature of the 2 pipes out of the back of the stove? BE CAREFUL they might be VERY hot indeed.
Unburnt fuel in the morning, I'd open the bottom vent a touch more.  Like said above, with Solid fuel air from the bottom will help with combustion.  With our Dunsley we tend to turn the vent down to 3 or 4...  But each stove is different and have their own characteristics in terms of burn rate.
What are you burning?  Is it solid like anthracite or an ovoid type.  We always had an issue with solid anth, it burns when fresh but requires fully open vents later on and even then it leaves lots of clinkers behind, I had to burn it with a log or two to get the most out of it.
Also check around you may have pipe stats somewhere that control the CH pump operation, I'm no heating engineer, but i'd expect you'd have one to set the pump going when water reaches the desired temp, and one which shuts the pump off when the water temp drops below a certain temp.
