recordplay Posted October 23, 2021 Share Posted October 23, 2021 (edited) After a fair bit of rainfall this damp/wet patch keeps appearing in my cellar. It looks like the previous owner has cemented there, so not sure if its an issue that has been there before. Nothing came up on the house survey when I bought the house. Any advice on what to do with it. It drys up after a few days and it definetly doesn't appear to be dripping from above as I can't feel any wet areas above. Seems to be coming from below, and like I said mainly when we have heavy rainfall. Really hard to check the surrounding rooms as its right below in the cellar so you cant access anything beyond the breezeblocks or concrete floor. Was thinking of painting over the floor with garage floor paint. Is that a good idea? or should I do any other treatment first? Edited October 23, 2021 by recordplay Spellcheck Link to comment Share on other sites More sharing options...
ToughButterCup Posted October 23, 2021 Share Posted October 23, 2021 You ain't going to like this...... shovel, spade, hole. Or digga ? French drain round the edge of your garage and anything else you can do to lower the water table. Wait for rain. Think of England, Harry and Saint George. 1 Link to comment Share on other sites More sharing options...
markc Posted October 23, 2021 Share Posted October 23, 2021 It’s a cellar … if this is an older house then it was built to be cold and damp. If you want to stop water getting in then it’s a big outside drain as above, otherwise you can only manage the water once it’s inside, drainage channel, sump, pump etc. 2 Link to comment Share on other sites More sharing options...
saveasteading Posted October 23, 2021 Share Posted October 23, 2021 54 minutes ago, markc said: it was built to be cold and damp Making it dry and even warm, ie into a proper room would be expensive. If that is the worst it gets then you are lucky, and perhaps you can live with it. A small sump and an automatic pump (£100 incl pipes) will probably suffice if you want rid of it. Let's hope that forming the sump doesn't break a barrier and cause more water ingress. Unlikely but take it slowly But first, check if any outside pipes or surfaces are casting water in the direction of this wall. If so, change that as the priority. Link to comment Share on other sites More sharing options...
SteamyTea Posted October 24, 2021 Share Posted October 24, 2021 15 hours ago, saveasteading said: But first, check if any outside pipes or surfaces are casting water in the direction of this wall. Yes. Try and establish if there is soakaway nearby. My basement used to get a good 6 inches of water in it. Link to comment Share on other sites More sharing options...
