Dunny1234 Posted October 18, 2021 Posted October 18, 2021 Hi, I’m approaching sorting the floor out on the ground floor of my self build. The FFL build up consists of: 100mm insulation 75mm screed 30mm floor covering. 205mm total The wife wants engineered herringbone, researched it and most recommend glueing it down. Most the samples are 15mm thick, and I’m assuming 5mm of adhesive? Does this sound correct? Has you’ve noticed I’m shy 10mm for the FFL. Do I, 1.lay an additional 20mm of insulation, and reduce screed depth by 10mm. Or, 2. Leave insulation at 100mm, and increase depth of screed to 85mm? Any advice would be gratefully received thanks
markc Posted October 18, 2021 Posted October 18, 2021 For herringbone the floor needs to be flat. The glue will be vertically nothing so allow 1mm at most to account for minor humps and dips
nod Posted October 18, 2021 Posted October 18, 2021 Increase the depth of your screed It will only cost about £1.50 per m2
Adsibob Posted October 18, 2021 Posted October 18, 2021 I would increase insulation by 20% or even 25%. May save you a bit of heating costs in the long term.
tonyshouse Posted October 18, 2021 Posted October 18, 2021 I would go 300mm insulation, you only get one chance, insulants are cheap compared to heat losses, no comparison when comfort enters the equation
