We are building with an insulated raft foundation and ICF and I have seen mention of these in various topics, and have scoured my architect and SE drawings and notes for mention of these on our build. I have investigated what they are, and what they do, but its still not obvious as to whether they are needed on not.
Awaiting the inevitable differences of opinion with interest ?
We put them in (Triton waterbar) even though we have waterproof concrete rafts. We questioned their necessity as they are expensive but both professionals stated that we should use them.
......is keep water in place in water retaining structures, to close off a joint which might be a weakness.
If you are building above ground, have a well-detailed damp-proof construction, and it is not a water tank then you should not need one.
Or it is a simple bar across a flat door threshold to keep the rain out.
@SteamyTea, not sure on the Regs related to this, but as I am building a partial basement, waterproofing is a definite requirement and from what I have read waterbars seem to be a necessary part of that waterproofing (Type B). I will now be fitting one (now I have read my plans again) and so a BBA approved product is the order of the day.
Seems the closet to Bristol one gets, the more of the ground floor gets covered.
If I dig down more than a metre it would be called a tin mine.
I am an expert on this from watching Poldark, which defines all the SW.
When times are tough you hope to find a shoal of tin or a seam of pilchards, or cause a wreck.
Yes, we are about to reopen all the fish mines.
And all the girls in Ilogan are as horny as Demelza, even allowing for her hip displacement
Poldark Season 4 - Demelza Poldark Official Picture ...
6 hours ago, BotusBuild said:
Any other recommendations apart from Happy Vally's Triton waterbar.
RX101 , i don't use any other and its what most designers spec as standard on large RC frame projects where required.
