I understand a standard ring circuit wiring.
However if one double socket on that ring was at a high level and 'user' (substitute for FIL) wanted it switched by a light switch, how is this done?
20A switch placed into the ring with switched live out to said socket?
Perhaps one @Onoff@ProDave can answer quickly?
6 minutes ago, ProDave said:
Yes but I would prefer a 45A DP switch  or a switched FCU
Switched fcu with what size fuse?
13A unless there is a good reason for lower.
Thanks for the prompt reply.
Does such a thing as a 2 gang fcu exist, couldn't find one on a quick Google.
It’s standard practice to have a switched spur control an appliance, you could put 2 side by side or build something with grid switches
