PieInTheSky Posted August 19, 2021 Share Posted August 19, 2021 Hi, I'm fitting a new kitchen. The corner unit and next ones either side of it are all good (don't you just love laser levels?). On one wall I've got to fit an integrated Washing machine. The Washing machine dimensions say width is 600mm. I'm still waiting on delivery of the machine and can't put the fitting on hold until it arrives. Presumably I've got to leave 600mm space for the washing machine plus a few mm either side to allow it to slide in/out? Or do I? Should I space the next unit exactly 600mm away from the last (I'd use a spare existing unit as a temporary template) or do I space the next unit in the run with a (say 2 or 3 mm) gap on either side? Thanks. Link to comment Share on other sites More sharing options...
markc Posted August 19, 2021 Share Posted August 19, 2021 55 minutes ago, PieInTheSky said: Hi, I'm fitting a new kitchen. The corner unit and next ones either side of it are all good (don't you just love laser levels?). On one wall I've got to fit an integrated Washing machine. The Washing machine dimensions say width is 600mm. I'm still waiting on delivery of the machine and can't put the fitting on hold until it arrives. Presumably I've got to leave 600mm space for the washing machine plus a few mm either side to allow it to slide in/out? Or do I? Should I space the next unit exactly 600mm away from the last (I'd use a spare existing unit as a temporary template) or do I space the next unit in the run with a (say 2 or 3 mm) gap on either side? Thanks. Hi, I always allow 610mm. That way any variances in floor level or foot adjustment do not cause the machine to jamb in the hole and lean on a side panel as this causes the adjacent unit and doors to vibrate Link to comment Share on other sites More sharing options...
PeterW Posted August 19, 2021 Share Posted August 19, 2021 Built in ..?? Or slot in ..?? Leave 5mm either side and if you can add some nitrile foam pads on the panels on the machine to stop vibration. Link to comment Share on other sites More sharing options...
joe90 Posted August 19, 2021 Share Posted August 19, 2021 Personally I hate built In washing machines as they wobble about too much (IMO) and can shake the cabinets next to them. The gap will depend on the door you have to cover it. There was a Thread here somewhere where they used two doors and a wider gap to leave plenty of wobble room. Link to comment Share on other sites More sharing options...
Temp Posted August 19, 2021 Share Posted August 19, 2021 Measured our Bosch and its 596 or 7 wide. https://www.theguardian.com/money/2017/aug/13/washer-dryer-too-deep-replacement-ao "...the majority of standard UK front-loading washing machines are roughly 850mm high and 595mm to 600mm wide. They are designed to fit into a standard kitchen width space of 600mm, with width (not depth) the one dimension that is strongly adhered to by most manufacturers." Link to comment Share on other sites More sharing options...
