1 of my neighbours (there are a few of us building in this project) has just found this issue, I'm going to check my build after work to see if we have the same issue and will add a photo
Our floor build up above insulation is 50mm screed and 20mm floor finish (engineered wood), this finished height is level with the concrete door threshold and would mean the wood within the door is higher.
We have at least caught this before the screed, and presumably the best idea is to grind the door threshold down - note I'm not sure on the best term if this is the threshold/cill/etc
Just thought I'd see if there are bright ideas that I'm missing?
When you say wood within the door, I presume you mean the frame? And what door, sliders, bi fold etc?
a sketch would help
Highly artist drawing as below.
I think it will just have to be a high threshold (apologies as I wasn't clear the wood was regarding the engineered wood floor finish) or we grind it down so we can lay it flat
At least one door will have to be level access, so lay a thicker screed to raise the entire floor a bit, or grind down the threshold of at least one door.
That’s a very neat back-of-a-fag-packet drawing :)
hmmm, looks like some cill  grinding will be on the next job list
Thanks all.
The builder has put his hands up about it being the wrong height and will sort - cill grinding and at their own time/cost
Which means I don't have to reach a decision or alternative and can concentrate on the other N+ items currently being juggled
