BenP Posted July 22, 2021 Posted July 22, 2021 Any thoughts or preferences on the above. I recognize the difference between the two - Foamglas Perinsul is stronger (throughout) but less thermal performance. Thermoblock performs better but achieves compressive strength via inserts within it. It strikes me that the Foamglas has the benefit of acting just like a block so should be easier for the groundwork to adapt to? Most builders don't seem to be aware of the type of products or detail it's associated with!!
BenP Posted July 22, 2021 Author Posted July 22, 2021 Perinsul marginally cheaper from searches - 1.5k vs 1.6k.
Oz07 Posted July 22, 2021 Posted July 22, 2021 How much of a difference do these make compared to a dry airated brickette?
A_L Posted July 22, 2021 Posted July 22, 2021 1 hour ago, Oz07 said: How much of a difference do these make compared to a dry airated brickette? About 80% less heat conduction relative to dry autoclaved aerated concrete 2
BenP Posted July 22, 2021 Author Posted July 22, 2021 I wasn't aware of the exact figures so ta! We're having a suspended beam and block floor due to ground conditions so it's the one weak point in the thermal envelope - especially as the roof and walls will be timber frame insulated between and over.
Moonshine Posted July 23, 2021 Posted July 23, 2021 Have you also looked at armtherm? https://www.armatherm.co.uk/ 1
BenP Posted July 23, 2021 Author Posted July 23, 2021 Thanks - fewer bits of information and suppliers online but I'll get in touch.
Moonshine Posted July 23, 2021 Posted July 23, 2021 3 hours ago, BenP said: Thanks - fewer bits of information and suppliers online but I'll get in touch. Go direct to Sales@armadillonv.com i was quoted in October last year Armadillo ARMATHERMTM 500-160 Thermal Breaks 2000mm x 100mm x 50mm Blanks TB1 £20 per unit Armadillo ARMATHERMTM 500-250 Thermal Breaks 2000mm x 100mm x 50mm Blanks TB2 £20 per unit
BenP Posted July 23, 2021 Author Posted July 23, 2021 Thanks - looks positive. I'm going to get the engineer confirm what compressive strength he's after beneath the sole plate. ? - might inform the decision!
GEO-PAR Posted January 8, 2024 Posted January 8, 2024 Can I ask what you went with in the end and if you have any advice you can share from experience gained? Asking myself the same question right now. Cheers
