21 minutes ago, ProDave said:
Care to explain how it works?
Not exactly sure, but I think its some kind of relief valve that opens a little if the outside temp drops. They are fitted on the external pipe work.
relies on the pump punning continuously I'd guess. It's one thing water expanding as it cools, but a small fixed pocket of water freezing might be something else...
If the pump runs continuously it is never going to freeze.
How will a relief valve work to protect anything if the water is not flowing?  It will freeze even if vented to atmosphere.
There is either something extremely clever here, or I just can;t see how you can avoid antifreeze in the pipework to an outside unit.
