4 minutes ago, ProDave said:
Probably a single twisted pair cable.
Initially I thought that, but as it is measuring ripples won't they get cancelled.
Why do you need to extend it? The extra resistance may change the readings.
A CT is a current transformer.  Depending how it is configured (load local to transformer or load in the measuring device) the cable will be conveying a 50Hz voltage or current.
All you want is that signal to arrive at it's load with no loss, and not picking up any externally induced signal, hence the twisted pair.
The inverter is 15m of cable from the grid supply.
I was thinking of using Cat5 cable...
