Oil fired combi, UF heating and radiators
gdal
We are renovating an old stone house in Oxfordshire, about 145 sq metres. Two people and two bathrooms, but unlikely that both bathrooms will be in use simultaneously. This will be a  complete new system with UF heating downstairs and radiators upstairs. I don’t think we can get the house up to a level where ASHP will keep us warm enough.
No mains gas, and no place to install LPG tank. There is room for an oil tank
So I’m thinking a new oil fired boiler which will be inside the house. I’d like not to have to find room for a hot water tank.
Does anyone have experience oil fired combi boilers such as a Worcester Greenslave  ? I don’t think there are many brands that do oil combi boilers.
(I must admit I have thought about putting in electric heating. I know it’s really expensive to run, but the install costs would be massively lower, so the oil fired payback time is probably at least 5 or 6 years. And by then it’s possible that electricity unit cost per Kw might be lower than oil …..)
Oil boilers aren't a great match for UFH unless you can add a buffer tank of some sort. Oil boilers don't modulate their burner, instead they turn the burner on and off to maintain the required flow temperature. This is a bit like driving a car in stop start traffic. So you might find the burner cycles on and off a lot if only one UFH loop is calling for heat. We fitted a thermal store which acts as a buffer. The store supplies the hot water for both the UFH and DHW. When the temperature in the store falls the boiler fires up and in our case runs flat out until the store is back up to temperature. The down side is that a thermal store can leak a lot of heat if not well insulated and some leave a bit to be desired in that respect. This was our first oil boiler so not sure how big aa problem the cycling issue is.
How much insulation is going under the floor?
You will if you size the ASHP correctly.
12, 18 or 25 kW is the power, this is independent of the technology used to generate it.
+1 to this.
@gdal Size the rads to run at d30°C and the UFH with a small buffer or LLH and then put a slimline UVC in a cupboard and you’ll have a full electric system anyway. You need to start with the basics and a heat loss calculation first.
I would really like to use an ASHP but I’m concerned that given the solid stone walls, which we can’t insulate, we just won’t be warm enough.
the house is currently pretty much derelict so I’m struggling to see how we can do a heat loss calculation until the renovation has been done (windows, doors replaced, new Limecrete floor). And I need to plan for the new heating before the renovation starts!
Also, can an ASHP be sited away from the building itself? I don’t want to have it on the gable wall under the bedroom window, which is pretty much the only place I might get permission (listed building). Could it be say 5metres away?
Yes.
For a Monobloc, it's preferred to have the ASHP within 10m of the cylinder. Mine is 14m, so I uprated the insulated twin duct between the two.
If you have to go significantly further apart you could consider a split system which are good for 30m between them. But this does reduce your options on ASHP you can use.
Edited by IanR
1 hour ago, PeterW said:
How much oil do you currently use
House has been uninhabited for a number of years.
But knowing the power of the oil burner could be useful.
The heat loss calculation for them is easy then, and won't change.  Just need to know what they are made from and how thick and air leaky.  Just don't get side tracked into thinking they will 'store energy'.  Just simple conductance and wall area is all that is needed.
new Limecrete floor
Why?  Do you like the damp.
I've got no current data on oil consumption, because there is currently no functioning heat supply at all. The house has been empty for a few years, and the last occupant used propane bottles and a combi boiler. There is no room for an LPG tank, no mains gas. So my options are oil  (there is room for a tank) or electricity.
Upstairs we have floorboards on joists, and will keep that arrangement. So that means radiators.
Downstairs we will dig out the old solid floor to 300mm and install limecrete and UFH.
There is a small attached outhouse, about 2 sq metres, that adjoins the kitchen, potentially the boiler room. Maybe, if I insulate this small building properly it could house both  boiler and cylinder.
Appreciate the input, thank you. Really I need to get a ....what heating engineer? to come and assess the specifics of the house, and advise.
I'm near Abingdon, Oxfordshire, if anyone has a recommendation. Not sure if that's allowed on here, so if not apologies.
Thank you
54 minutes ago, Marvin said:
yep aware of what it is, but if you’re digging up a floor to renovate then it’s irrelevant. LABC have an “approved detail” but it’s notoriously difficult to deal with and last check it was near 3 times the cost of a concrete floor.
You may want to go 100mm deeper and put 200+mm of insulation in.
What do you consider the minimum qualification is for an 'engineer'?
The walls are solid stone and rubble with no DPC. I believe that putting down a concrete floor with an impermeable membrane will potentially cause problems as moisture in the soil will migrate to the edges of the slab and into the walls. So breathable structure is advised. I can’t go deeper than 300mm
