learner Posted June 18, 2021 Posted June 18, 2021 My builders have installed 100mm insulation under the slab. Is this correct??
A_L Posted June 18, 2021 Posted June 18, 2021 @learner , it can be. It will slow the response time of any UFH but will enable you to store more energy in the slab.
learner Posted June 18, 2021 Author Posted June 18, 2021 There's no UFH going in, i just wondered if it was correct procedure
Jilly Posted June 18, 2021 Posted June 18, 2021 Yes, probably. Can you look at your Building Control drawings, if not on a Building Notice?
learner Posted June 18, 2021 Author Posted June 18, 2021 Building control are signing jobs off as we go and this has happened today
James Newport Posted June 18, 2021 Posted June 18, 2021 31 minutes ago, A_L said: @learner , it can be. It will slow the response time of any UFH but will enable you to store more energy in the slab. how does insulation under the slab slow the response time of UFH?
A_L Posted June 18, 2021 Posted June 18, 2021 19 minutes ago, James Newport said: how does insulation under the slab slow the response time of UFH? The temperature of the slab has to be raised before it starts to heat the room
Gus Potter Posted June 18, 2021 Posted June 18, 2021 Yes putting the insulation under the slab is fine. What you are doing is bringing the slab into the inside of the insulation envelope, just like if you have some masonry walls inside. In some ways you have a big storage radiator (hate to say it but often called thermal mass) which can help stabalise the temperature in the room. It's important that you carry the insulation below the slab up the sides so you "wrap" it fully in the insulation blanket. There are practical benefits in that you often have something more solid to lay your floor on and build non load bearing partition walls off.
James Newport Posted June 19, 2021 Posted June 19, 2021 9 hours ago, A_L said: The temperature of the slab has to be raised before it starts to heat the room But how does insulation under the slab slow that process?
dpmiller Posted June 19, 2021 Posted June 19, 2021 It doesn't. But Insulation *over* the slab with UFH in a screed or board above will be more responsive. 1
