can you fill gaps in lining paper with easifill?
Hi,
Does anyone know if I can use easifill to fill in gaps in lining paper at all?
Any advice would be appreciated.
Thanks.
4 minutes ago, tonyshouse said:
Yes, need to be very carefully if sanding as paper may ‘rough up’
ah, it is intended for painting though. so could you suggest another method that would be kinder to the lining paper at all?
Thanks.
If your going to paint the lining paper
I would think twice about filing
You will highlight every joint
Probably neater and quicker line over what you have
if I am going to line over it, wouldn't I then have lots more overlaps that would be highlighted when I paint it?
You answered your own question
Strip it and start again
I cannot. it is over wallrock which is on the wall horizontally and the lining paper is on vertically. it would basically take it off. hence my question about other possibilities to remedy :)
but thanks for your advice
I filled some minor gaps in lining paper with caulk a few years back...despite 5-6 coats of paint it's glaringly obvious it's there as it seems to stay shiny that bit. Haunts me each day. ?
lol, I think i will leave it be hahah, thanks for sharing the story.
