TryC Posted May 21, 2021 Posted May 21, 2021 Hi All, Does anyone know that the difference is between these two products or do they essentially do exactly the same? I am looking to fill in any cracks and hair line fractures in the walls and holes before I seal it to then be lined then paper/painted. Any advice would be appreciated.
MikeSharp01 Posted May 22, 2021 Posted May 22, 2021 Yep - Easi-Fill every time, great stuff use it for all sorts - including repair of ornate plaster cornicing, sands perfectly. Don't let it go too far out of date, it goes hard VERY fast when it gets old, and I always use the 60 minute stuff anyway - the 20 minute stuff is a bit quick for me, I cannot throw it on fast enough, but you can re-coat in 30 minutes.
TryC Posted May 24, 2021 Author Posted May 24, 2021 On 22/05/2021 at 07:09, MikeSharp01 said: Yep - Easi-Fill every time, great stuff use it for all sorts - including repair of ornate plaster cornicing, sands perfectly. Don't let it go too far out of date, it goes hard VERY fast when it gets old, and I always use the 60 minute stuff anyway - the 20 minute stuff is a bit quick for me, I cannot throw it on fast enough, but you can re-coat in 30 minutes. thanks! Yes, easifill is very easy to use!! and very easy to sand. I just sanded it down with relative ease. Do you think on application is enough or do you need another layer than sand before sealing it with sealer?
TryC Posted May 24, 2021 Author Posted May 24, 2021 On 21/05/2021 at 20:55, nod said: Easi-Fil is cheaper and easier to sand it sands like a dream! but the dust is intense! ha ha
saveasteading Posted May 24, 2021 Posted May 24, 2021 Easi-fil is one of my favourite products. Specially because it is sticky on a trowel and easy to handle, by amateur me. Then spreads and penetrates nicely when worked. Diall is own brand b&q /screwfix, and the qualities vary enormously. Could be fine. But Easi-fil is £20 for 10kg so that is where I would go. That fills a lot of cracks, and gaps, and hollows, and joints....
