Hastings Posted May 3, 2021 Share Posted May 3, 2021 Is it better to break the floor deck (t&gOSB on posi-joists) between 2 rooms, in order to better isolate sound transmission between adjacent rooms? Or lay floor as a continuous deck and build the stud partition over this? 2nd option quicker/easier but speed is not a priority. Link to comment Share on other sites More sharing options...
Dave Jones Posted May 3, 2021 Share Posted May 3, 2021 floor first. stud second. 1 Link to comment Share on other sites More sharing options...
James94 Posted May 3, 2021 Share Posted May 3, 2021 Im going to stud soon, walls will be built straight onto 22mm kaberdeck t&g. Never really thought about this, hope I’m not about to go it wrong. regards. James Link to comment Share on other sites More sharing options...
nod Posted May 3, 2021 Share Posted May 3, 2021 When your putting your studs in Any that land parallel and between joists Should have noggins glued and fixed at 600 center's Directly under the floor 1 Link to comment Share on other sites More sharing options...
Dave Jones Posted May 4, 2021 Share Posted May 4, 2021 14 hours ago, nod said: When your putting your studs in Any that land parallel and between joists Should have noggins glued and fixed at 600 center's Directly under the floor interesting, where does it spec this in the regs ? Link to comment Share on other sites More sharing options...
Marvin Posted May 4, 2021 Share Posted May 4, 2021 15 hours ago, nod said: When your putting your studs in Any that land parallel and between joists Should have noggins glued and fixed at 600 center's Directly under the floor The stud needs good quality support and nod has said a good way to do it. If you rely only on the strength of the flooring between the joists it will sag over time because of the weight of the wall. I know! Have no idea where it might stipulate this but I have been in plenty of properties where the walls have sagged because the flooring has bowed because of this. In fact the last 3 properties! 1 Link to comment Share on other sites More sharing options...
Hastings Posted May 4, 2021 Author Share Posted May 4, 2021 It is described in the installation guide for posi-joists. (Not that it is specific to that type of joist.) Link to comment Share on other sites More sharing options...
