Farmer_Terry Posted May 1, 2021 Posted May 1, 2021 Hi All - I'm a newbie with a simple question that I have been unable to find and answer to. My wife and I are, shall we say, no longer in the first flush of our youth, and our existing heating timer / thermostat is way too complicated for us so I plan to replace it with a good old fashioned mechanical one that we can both work. I have done some research and the one that lo0oks most promising is the Siemens (Landis & Staefa) RWB2E Programmer but the thing that worries me is that it frequently seems to be followed by "24V". https://www.amazon.co.uk/Siemens-Landis-Staefa-RWB2E-Programmer/dp/B00FSBBPOQ Does this mean 24 volts? And if so, is that unusual? Is this going to be suitable? (I don't propose to do the work - I will get an electrician in for that). I would be very grateful for any pointers in this direction please Terry Chisman
Nickfromwales Posted May 1, 2021 Posted May 1, 2021 (edited) Yup. Simple job for a decent plumber / sparky Edited May 1, 2021 by Nickfromwales
Farmer_Terry Posted May 1, 2021 Author Posted May 1, 2021 Great. Thank you both so much. Where else can you get information like that? ? Terry
TonyT Posted May 1, 2021 Posted May 1, 2021 The internet.... type in make model and add installation manual.
Farmer_Terry Posted May 2, 2021 Author Posted May 2, 2021 ? Oh dear, sorry, I wasn't asking for more information - I was commenting on the usefulness of fora like this where so much information is freely available. But thanks anyway. ? 1
MikeSharp01 Posted May 2, 2021 Posted May 2, 2021 23 hours ago, TonyT said: The internet.... type in make model and add installation manual. Yes but you need to know where to start and what all the guff you get back means / implies. We can help with the interpretations perhaps.
Rob99 Posted May 2, 2021 Posted May 2, 2021 (edited) 1 hour ago, Farmer_Terry said: fora So pleased to see the correct grammatical use of the plural of Forum..... ? I've used those timers before. Very easy to use, I fitted one for my 80yr old Mother. Edited May 2, 2021 by Rob99
Farmer_Terry Posted May 3, 2021 Author Posted May 3, 2021 13 hours ago, Rob99 said: So pleased to see the correct grammatical use of the plural of Forum Standards have to be kept. ? Having thought a bit more, I do have one other question - is this timer suitable for a combi boiler please?
Rob99 Posted May 3, 2021 Posted May 3, 2021 (edited) My mother has a standard boiler with HW cylinder so using both timer bits. With a combi the hot water is instantaneous (ish) and the boiler fires when there is flow through the hot water system when a tap is turned on so to use this timer you would just set the hot water to permanently on and let the boiler do it's thing. Maybe you don't even need to connect the HW part of the timer anyway if it's a combi. Edited May 3, 2021 by Rob99
Nickfromwales Posted May 3, 2021 Posted May 3, 2021 (edited) Only 1 channel required with a combi. This is a standard controller in that instance; https://www.screwfix.com/p/drayton-lp711-timeswitch/39024?tc=CB1&ds_kid=92700055281954502&ds_rl=1249404&gclid=Cj0KCQjwvr6EBhDOARIsAPpqUPGrFCfJSVFNTkucCLu4d3WrezSzYYT-csZUKleAzMrbf48YGiDxcl8aAtSxEALw_wcB&gclsrc=aw.ds This has 'volt free' contacts so can be used with either low or 230v Edited May 3, 2021 by Nickfromwales
Farmer_Terry Posted May 4, 2021 Author Posted May 4, 2021 Rob99 - thanks, that's about what I was hoping. NickfromWales - thanks, I had thought about a single channel timer, but the one you show is digital (which I'm trying to avoid) and probably a bit more tricky to set than my wife can cope with, which is why I wanted a mechanical one - hence the Siemens, which I can't find in a single channel.
Farmer_Terry Posted May 4, 2021 Author Posted May 4, 2021 Found it! https://www.bes.co.uk/siemens-rwb30e-single-channel-time-switch-19097/ ?
