Vijay Posted April 15, 2021 Posted April 15, 2021 Never used one, but looking to buy one for now and again use. Don't really want to spend loads as I doubt I'll get the use out of it, so looked at Screwfix own brand for some guidance, something like this https://www.screwfix.com/p/erbauer-ero400-125mm-electric-random-orbital-sander-220-240v/581fx or the larger one https://www.screwfix.com/p/erbauer-ero450-150mm-electric-random-orbit-sander-220-240v/285fx Both good reviews, but was surprised that motor bushes can't be changed. Is that common these days or only on the cheaper stuff? Any recommendations for one? Cheers Vijay
markc Posted April 15, 2021 Posted April 15, 2021 you wont go wrong with an Erbauer, you can pay silly money for orbital sanders and its pretty pointless. They all do the same job, yes some are vibration damped buy you wont tell the difference
Vijay Posted April 15, 2021 Author Posted April 15, 2021 If it was a daily use tool, I don't mind spending more, but for a now and again tool, I'm not a tool snob lol
TonyT Posted April 15, 2021 Posted April 15, 2021 I’m a festool sander man, but if it’s for a few occasions get one out of Aldi/Lidl, use and abuse and if it breaks get a refund. Local store for easy return.
Vijay Posted April 15, 2021 Author Posted April 15, 2021 I did look on both of their sites and Lidl have a DIY event but no sander
SteamyTea Posted April 16, 2021 Posted April 16, 2021 I have always found a quarter sheet orbital palm sander better. And you can by a roll of paper for it and not have to pay over the odds for the velcro ones.
Vijay Posted April 16, 2021 Author Posted April 16, 2021 6 minutes ago, SteamyTea said: I have always found a quarter sheet orbital palm sander better. And you can by a roll of paper for it and not have to pay over the odds for the velcro ones. from reading on a few websites, you get a better finish with a random orbital sander though, from sanding in a swirl pattern. As I said, I've never used one so I don't know..............
markc Posted April 16, 2021 Posted April 16, 2021 14 minutes ago, Vijay said: from reading on a few websites, you get a better finish with a random orbital sander though, from sanding in a swirl pattern. As I said, I've never used one so I don't know.............. Depends what you are sanding, SteamyTea is correct regarding economy and general use - gets into corners better etc. Circular random orbital you can use the edge for digging is a bit but needs practice or you will get swirl marks much easier than a rectangular plate
daiking Posted April 16, 2021 Posted April 16, 2021 34 minutes ago, Vijay said: from reading on a few websites, you get a better finish with a random orbital sander though, from sanding in a swirl pattern. As I said, I've never used one so I don't know.............. I’ve had the swirls with a sheet sander. I need something cheap for a job so I’ve just bought this off Amazon for £25 Orbital Sander, TACKLIFE 350W 13000 RPM 125mm Random Orbital Sander with 12 Pcs Sandpapers, 6 Speeds Electric Sander, High Performance Dust Collector, 3m Wire/ PRS01AS https://www.amazon.co.uk/dp/B08PBBJF4M/ref=cm_sw_r_cp_api_glt_fabc_D69C18EAES65YR8GMXK2?psc=1
daiking Posted April 21, 2021 Posted April 21, 2021 On 16/04/2021 at 08:40, daiking said: I’ve had the swirls with a sheet sander. I need something cheap for a job so I’ve just bought this off Amazon for £25 Orbital Sander, TACKLIFE 350W 13000 RPM 125mm Random Orbital Sander with 12 Pcs Sandpapers, 6 Speeds Electric Sander, High Performance Dust Collector, 3m Wire/ PRS01AS https://www.amazon.co.uk/dp/B08PBBJF4M/ref=cm_sw_r_cp_api_glt_fabc_D69C18EAES65YR8GMXK2?psc=1 Seems decent enough so far
